I have been trying to export 3D views of Revit to SAT format using dynamo, but Geometry.ExporttoSAT gives error “conversion of backing object to geometry failed”.
if would be helpful if any once knows the reason for the error
I guess you can export only solids and surfaces geometry to SAT, filter out the rest?
Hi @ishanifarazmuraz …does it work if you export directly in revit ?
