I started using Dynamo 3.3 this week and only now I noticed the Revit Library isn’t showing on the side. The nodes are there, but they only appear by left-click search menu at the workspace.
What have I missed regarding the changes of the UI?
Certainly should be there. But I notice you have one in the add-ins section, which makes me think one of the customizations in your environment is incorrect.
Disable all packages and view extensions and see if that clears it up.
If not, also disable your Revit add-ins and customizations.
Once you get it back, start enabling groups of customizations until the issue comes back - this will help you identify the offending one. Update that (or reach out to the author to get it updated) and you should be good to go.
