How do you type scale into dynamo considering the quotation marks.
For instance, how can you type ‘1"=10’-0"’
You’ll have to use a string node.
And FYI, if you’re trying to set the scale of a drawing I believe you have to use Scale Value.
I’m trying to filter by scale value. When I use string value it doesnt equal each other.
If you’re using GetParameterValueByName it will return the Scale Value, not the name of the scale.
Edit: An image is always helpful.
As you can see the string value does not match the scale value. Set Graphic Scales.dyn (29.2 KB)
You have a space in front of those strings.
Those strings are directly from viewscales on Revit sheets. Even when I put space into my string node, they are not equal.
Is there a reason you’re checking the sheets and not the views?
Its checking the viewports that are on sheets.
Oh sorry. I had to bypass that node cause I don’t have it. I replaced it with a newer node so we’re on the same page again.
Is it possible those views are using a custom View Scale? All the other views return the scale value like normal.
EDIT: Nope. It looks like custom scales return a -1.
Strange. Viewports still returned a 120 scale value for me. Glad you got it working.
