TypeError: unsupported operand type(s) for -: ‘str’ and ‘float’
I have a problem with this code:
import sys
dataEnteringNode = IN
# Place your code below this line
Lista_P=IN[0]
np=IN[1]
ns=IN[2]
bpX = IN[3][0][0]
bpY = IN[3][1][0]
#bpX = IN[3][0]
#bpY = IN[3][1]
Sec=[]
a=0
b=0
c=-1
Pontos_T=[]
for a in range(0,np,ns):
	c=c+1
	b=0
	Pontos=[]
	for b in range(ns):
		xp = (Lista_P[a][2]) - bpX   # <- Line 28
		yp = (Lista_P[a][1]) - bpY
		zp = (Lista_P[a][3])
		Pontos.append(Point.ByCoordinates(xp,yp,zp))
		b=b+1
		a=a+1
	Pontos_T.insert(c,Pontos)
OUT = Pontos_T
i have this erros mensage:
Warning: PythonEvaluator operation failed.
File " < string> ", line 28, in < module>
thanks
I’m not sure which line 28 is… and I have no idea what your inputs are…
But it could be the in range.
is ns a number or a string? It needs to be a number, you can cast it to be a number if it’s “23” not 23…
int(ns) would fix that. IF that’s the issue.
Otherwise
You’re mixing strings + numbers… or trying to use a string where you should use a number.
Check what your inputs are and make sure they’re the correct type.
Hi
I have a CivilReport
And this Dynamo
What type of data is coming out of here?
See the colour?
Text (strings) are orange
Numbers are blue.
As I said in my first reply… Make sure the inputs are the correct type.
Convert your strings to numbers.
You can do this before you feed it into the python node or within the code.
float() or int()
But i have number in properties excel.
And you’re importing to an entirely different program.
If it’s orange in Dynamo it’s a string.
Check the ‘read as strings’ input for the read excel node.
use Default Value, checked
Consider ‘false’ as the input, which will mean the node will try to keep a number format instead of a string.
No resolve.
I transform string list in number
Try something along the lines of:
Listx=IN[0]
Lista_P =
for i in Listx:
for j in i:
Lista_P.append(int(i))
You could add a helper function near the top of your code
nc = lambda n: eval(n) if isinstance(n, str) else n
then modify the lines
Your code uses multiples of the same variable (like this b=0, for b in range..., b=b+1) which could result in unexpected results
As far as I can tell you want to process all the points in lists of ns chunks.
You could do this very efficiently by mapping a point function over all the excel rows and then breaking the list into chunks
def chunks(lst, n):
    for i in range(0, len(lst), n):
        yield lst[i : i + n]
def point_bc(lst):
    return Point.ByCoordinates(lst[2] - bpX, lst[1] - bpY, lst[3])
Lista_P = IN[0]  # Excel
ns = IN[1]  # Step
bpX = IN[2][0][0]  # E/W
bpY = IN[2][1][0]  # N/S
pontos = list(map(point_bc, Lista_P))
Pontos_T = list(chunks(pontos, ns))
OUT = Pontos_T
