Type Parameters of Families
Are we able to update type parameters for all of a given family type through dynamo. Like arrowhead style for all text types?
Hello John,
As a matter of fact, you can change the parameters of all text types:
2015-01-08_111117
However arrowheads are notoriously difficult to extract and you need to feed an “ArrowheadType” into the SetParameter node.
You could try to select arrowheads if you know their exact names:
2015-01-08_121806
Dimitar you are the man! Thank you so much for your help! I was trying to create a node to set all of our text to have the same arrowhead types for consistency through a project. I am all set now thanks to you!
I hope to one day be a dynamo guru as well.
-John
Sorry to Necro this thread. I can’t quite make out the image that Dimitar_Venkov posted.
I’m trying to replace all the arrowheads for types in a family. Is this still a valid way of doing this? If so, can someone help me out and guide me through the process?
Thanks!
If you need more assistance. Go ahead and start a new thread. :slight_smile:
Thanks John!
I’m very new to Dynamo. So once I get all the instances of types using a specific arrowhead, how do I replace it?
You need to set a type parameter for this. Go ahead and edit the custom node “Arrowhead Assigner” in Rhythm and it should guide you in the right direction.
