Turn off All links in a 3D View template
I am trying to turn off all links in my Navisworks view- to make sure all links are turned off before model share, the example solutions I have seen are turning off model categories within the link, is there a way to toggle of the link visibility of a template?
you can try this
Thanks,
I have an issue. I want to hide all my links at once, as you can see from the modified script, I collected all the links in my model, and collected all the 3D view templates. Strangely when I run the script only one link is turned off instead of one.
Hi @femi.osewa
Try setting the View SetElementOverrides node’s lacing to longest (right click > Lacing > Longest)
Hope that helps!
Thanks a lot. it works!!
