Trouble Setting Dimensions on Curtain Wall using Rhythm
Hello Dynamo Community!
I’ve had a look around and i don’t think this question has been asked before (hopefully). I’m having a little trouble setting the dimensions on my Curtain Wall. Briefly, what i was tying to achieve was a quick script to set dimensions between internal curtain wall gridlines on a plan view.
The script seems to work as intended up till the point where it wont actually place the dimension. I think this could possibly be down to having not selected a dimension style?!
I’m pretty sure this is quick fix but it’s a little beyond me being a rookie at this. Could someone point me in the right direction?
Second Part of the script.
Not too sure this is a unique problem to Rhythm. Placing Dimensions is pretty difficult via the API in my opinion. Do you have sample files for us to test?
John,
Here a link to the file on my dropbox https://www.dropbox.com/s/hmggr9320wgvze5/CurtainWallGridDimension.dyn?dl=0.
I appreciate you having a look.
Have you had any luck with this? I cant even get your result
