Triangulation Difference
Hello everyone,
Is it possible to have the extrusion of smaller triangles from exactly the surface it cutting the bigger triangles …? Thanks in advance
Triangulation.dyn (64.6 KB)
Hello @Kumar_Kapadia,
I have the solution; this is not an elegant solution, but this is how you can achieve it. (DYN attached.)
Thanks,
Ritesh
DYN is here…Triangulation_Updated.dyn (83.4 KB)
Hello it doesn’t work with this version can u plz tell me from where to download to 1.1.1 ?
That was a Daily Build of Dynamo available on Dynamobuilds.com.
BTW, those builds can only be installed if you have Revit 2015 or higher installed on your machine.
If you want I can create the same graph for you on DynamoStudio 1.1.0
Thanks,
Ritesh
I use dynamo studio stand alone student version anyway i have revit 2016 but the dynamo version for that is also same that is 1.1.0…anyway will appreciate if u make the same graph for 1.1.0… thx
@Kumar_Kapadia The file below should explain the process of creating a cutting tool aligned to a surface.
VoidAlignedToSurface.dyn (13.0 KB)
In case you aren’t able to open the attached file, below is the code. The rest you should be able to rebuild from the image
//Icosahedron
p=(1+Math.Sqrt(5))/2;
a=Point.ByCoordinates({0,0,0,0,p,-p,-p,p,1,-1,-1,1},{1,-1,-1,1,0,0,0,0,p,p,-p,-p},{p,p,-p,-p,1,1,-1,-1,0,0,0,0});
b={{a[0],a[8],a[9]},{a[0],a[9],a[5]},{a[0],a[5],a[1]},{a[0],a[1],a[4]},{a[0],a[4],a[8]},
{a[1],a[5],a[10]},{a[1],a[10],a[11]},{a[1],a[11],a[4]},{a[2],a[3],a[7]},{a[2],a[7],a[11]},
{a[2],a[11],a[10]},{a[2],a[10],a[6]},{a[2],a[6],a[3]},{a[3],a[6],a[9]},{a[3],a[9],a[8]},
{a[3],a[8],a[7]},{a[4],a[11],a[7]},{a[4],a[7],a[8]},{a[5],a[9],a[6]},{a[5],a[6],a[10]}};
srf1=Surface.ByPerimeterPoints(b);
Wow …Thank you so much Sir :slight_smile:
