Hi all
I create a Triangle (flat) Pattern in the Revit family environment. then use in the dynamo with Lunch box Package. but in the family is deformation , In the event that Perfectly true in Mass environment Without using Dynamo Placed.
Solved
Could you maybe share your solution so people with a similar problem can use this topic as a help?
