Hi, I’m trying to define a script to define the topographic surface from the model line, I think it should be simple but there is nothing is in Dynamo, my idea is to define a sequence of sections then define a through topography, someone can you help me?
Thank you
Hello @paolo.campana
Use a Element.Geometry node to convert the model lines to dynamo geometry. Then you will see the dynamo geometry lines in the dynamo 3D view.
