To get Layout Profiles from Alignment
Hi, Is there any way to get only Layout Profiles from the selected Alignment in Dynamo for Civil3D ? (By Filtering out all the Surface profiles )
You could use the Arkance Systems Node Library:
With that you can create a FilterByBoolMask.
Something like that.
Hi, Thanks for the Reply. I am not able to access Profile.type node in Dynamo. Why it would be ?!
Profile.Type
I think you need this.
