I used the Get To-From Room package to retrieve the To/From room door numbers. I write the numbers back to shared parameters, ToRm and FromRm. Everything works fine for single and double flush doors. However, the function will not work for uneven doors. I assigned the shared parameters to the uneven doors as I had for the single flush and double flush doors. Any suggestions?
I would guess that if they do not appear in a Revit schedule either, this is not a Dynamo problem…
The parameters show up in the schedules (blank). Again, the data shows up for the single flush and double flush door when I run Dynamo. I’m wondering if there is something unique about the uneven doors. Thanks.
