Hi! This is my first post on this forum, but i’ve read a few posts since i started using Dynamo.
What im trying to achieve is following:
For each door-element, figure out which rooms it belongs to, and set the value of that question into a type-parameter (FromRoom and ToRoom).
This works sort of, quite easily, with the Doors.Rooms in the Clockwork-package.
The thing is, if i flip the door in the model, the FromRoom and ToRoom should change! It does not.
Any help would be greatly appreciated!
Well, sometimes you just cant stop laughing.
Activating the Room Calculation Point inside the family did the trick
Hi, I use this code, but in my project, the doors are in my Revit-Schedule correct, but in the Dynamo-Listing, they are not right. why could it be?05.3_Türenliste_mit Raum_geht nicht.dyn (68.3 KB)
Kulkul
February 16, 2017, 3:34pm
4
Hi @Heinrich_Boldt
Heinrich_Boldt:
You should start a new thread. This topic is very old. You could link this topic as a reference. Thanks!
