Read From-Room Door Parameters
Hello Community,
due to a project, I need to place door description texts on my plans. These description texts need to follow a certain key that is given by the client. One part of the description key is the room number.
Unfortunately, Revit doesn`t allow to use the “from-room” / “to-room” information as a parameter for description texts.
So I had the idea to copy the given information (from-room/to-room) to an extra shared parameter and map this with dynamo.
Now I failed to receive this information as a string from dynamo. Get Parameter Value by name doesn’t work to achieve a solution.
Thanks in advance.
Mark
@mark.surges ,
Hello, how you doing?
go via Python to get the information…
clr.AddReference('RevitAPI')
clr.AddReference('System')
doors = UnwrapElement(IN[0])
torooms = []
frrooms = []
for i in doors:
    torooms.append(i.ToRoom)
for x in doors:
    frrooms.append(x.FromRoom)
OUT = torooms, frrooms
KR
Andreas
Hi Andreas,
of course! Thank you so much. It worked as you said! Thanks a lot!
hi am getting this error.
I recommend using the node in Clockwork package for this task.
@Revit_Noob ,
It has to be modived in older versions…
or i think i did the screenshoot to ealry ;)… just experiment a little bit.
KR
Andreas
@jacob.small , @mark.surges
yes thats fine!
KR
Andreas
For some reason this node wasn’t part of my clockwork package anymore. I went Andreas way.
Seems like I am using not the latest clockwork version. I’ve got to check this out.
Thx
