Anyone ever seen Curtain Panel Thickness programmatically? It only seems accessible via the UI.
Not here:
Not here:
Only here:
Not here:
Not here:
Only here:
Have you tried archilab’s GetBuiltinParameter node. You’ll first need to check the internal parameter name tho.
I don’t know what the internal parameter name would be except “Thickness”. Cannot find in Snoop DB.
I thing that you are pulling the data from the wrong object. The thickness parameter for curtain panels is in the nested family type.
Try something like this:
yes, as already highlighted, this is a type parameter, so you should be looking in the type object. You can get the internal element from the SDK, from the revit lookup plugin or by using archi-lab’s “Get BuiltInParameter Name” node:
