I’m trying to find the node that can replace Curve.ShortestWalk, because it does not work in Dynamo 2.0.3. I know it could work properly in version 1.3.3, but I’m just wondering is there any other way I could use?
I have already created the mesh on the analysis surface and get the path, and now I would like these paths could only be restricted to run on the surface.
Is it possible to do that?
Double check that you have the latest lunchbox installed, as I believe it works when updated. Note there is some difficulty getting it installed sometimes, so you might have to go through the website not the Dynamo package manager.
Double check on what the node expects - A line from start node to end node. Creating a line by bear fit through the ordered pairs of points should solve the issue.
