Hello! I created scripts in Dynamo using version 2025.1.0 of the package “The Civil Nodes” and Civil 3D 2025, and everything worked correctly. However, when I try to use the same routine on another computer—also running Civil 3D 2025—and install the same version of the package, I get some missing dependencies. Does anyone know why?
Which build of Civil 3D is the second computer using? If it’s 2025.0 I think this would be expected. Both of you should be on 2025.2.4 or you’re missing some security updates which were concerning enough that a patch was released to keep you safe.
