I’m getting back into using dynamo for my projects, after spending awhile working on projects in Open Roads Designer. I downloaded the top node packages and I noticed that there my be issues installing Civil3DToolkit from the Package Manager. I remember that the Civil3dToolkit had many nodes for pipenetworks, surfaces, hatches, and other objects but after installing it there seems to be one or just a few nodes in each dropdown. Am I miss remembering the node package? Or was there an announcement that there’s a change to a different node package? I’m just starting back up and haven’t been following the online dynamo community for a bit so if someone help me get caught up or knows a workaround that can install all the nodes in the Civil3dToolkit package I’d be very appreciative.
Hi @jjay,
It may be related to the version of Civil 3D that you’re using. From Civil 2025.1 onwards, the Civil 3D Toolkit is unsupported. However, there are many more nodes available out-of-the-box (including for pipe networks), so it’s likely that you won’t need to use that package anymore.
For any other gaps that remain, I would recommend looking into The Civil Nodes package from @Anton_Huizinga.
Oh I see, yes I’m using the Civil 3D 2025 version. Thank you for the update!
