Text from CAD to Door Mark
Hello
I need to create a script that takes the value of the of a text from CAD and imposes it on the door in the Mark Parameter, here is what i came up with:
from there I need to find a way to find what tag corelates to what door, which is location.
The problem is, the tags are not in the same place as the doors, very minor difference, but it doesnt work, i thought i should look for a “closest” node which i found one in Orchid, but it doesnt do the trick.
could someone help/guide me to what is the best option to go from here?
how about set location or move by vector
Im not following?
just to clarify,
I want to take the value from the orange tags (linked CAD) and assign it to the doors “Mark”
我觉得你最好还是把CAD里的文字赋值到族的参数中,名称,类型都可以,然后使用门窗标记族来放置,这个比单纯的放置文字注释要强,而且是关联的。
Translated by google:
I think you’d better assign the text in CAD to the parameters of the family,both the type name and the type annotations can be used, and then place the door and window mark family , this is better than simply placing textnote, and it is related.
Hi @NERDASORUS just mean something or use set location after you have created your text/tag…if i understand right :wink:
Try something like this (I used text notes, but it should work the same for anything with points/values):
Mark doors by close text.rvt (2.0 MB)
Mark doors by close text.dyn (43.0 KB)
Three important techniques with this type of workflow are:
  1. Limit what you collect to active view only
  2. Pull points to the XY plane by discarding Z values
  3. Add a limit for how far away a note is allowed to be from a door to be matchable
