When i run this .dyn to have all get all the tags at the same offset from (the closest) Level) below,
but it only does the Tags with the value ‘gang’ all other Tags don’t get moved at all?
Also the Tag SetLocation gives null thought the Tags with ‘gang’ get moved?!?
I am a bit puzzled. Any one have a clue what i might be missing?
Try feeding just 1 tag and 1 location at a time for testing. Try 1 from gang, then one from your others each in turn. Based on this result it might help you figure out your issue. Looks like tag. SetLocation is from a custom package, It might not be designed to work with lists and be expecting a single value input?
