How to move Tag out of element
Hi Everyone,
I’m a fresh with Dynamo, I use automation tag element but I don’t know how to move tag out of element. Maybe change input node or python script.
I’m glad to waiting the answer. Thanks.
Tag select element.dyn (14.1 KB)
Hello @CrisHuy and welcome to the forum :wink: you could try translate your location point or set the location after, i use genius loci…you dont need point at parameter if it column you work on
Thanks @sovitek for the answer, but it still not work :frowning: .Some warning in here. And I didn’t see node “Tag Setlocation” in library.
hi you dont need point at parameter, it was just becaurse i test on a duct with line location…for columns it already have location point…set tag location is from genius loci pacage and can be installed from P manager…try as here
k
Thanks a lot @sovitek ,it’s work, but I have another question:
When I print, blue point appear in drawing, how can remove or hide them.
Go to view and turn your revit preview off
Thanks @sovitek .I’m appreciate your quick reply.
