Tag piles as per coordinate X and Y
Edit Moderation:
Tag piles as per coordinate X and Y value so it take X value in ascending order till Y is constant and move to new row (for a new higher value of Y) Y value and tag piles again for X(lower to high value) till the new constant Y value
clr.AddReference('RevitAPI')
clr.AddReference('System')
# Function to get the X, Y coordinates using direct access to Location property with unit conversion
def get_location_coordinates(element):
    location = UnwrapElement(element).Location
    if isinstance(location, LocationPoint):
        point = location.Point
        # Convert from feet to millimeters
        x_mm = point.X * 304.8  # 1 foot = 304.8 millimeters
        y_mm = point.Y * 304.8
        return x_mm, y_mm
# Retrieve selected pile elements from the model
selected_elements = UnwrapElement(IN[0])
if not isinstance(selected_elements, list):
    selected_elements = [selected_elements]
# Retrieve coordinates using direct access to Location property with unit conversion
coordinates = [get_location_coordinates(element) for element in selected_elements]
# Dictionary to store tag values based on columns
tag_values_by_column = {}
# Assign pile tags and update the "Mark" parameter
# Counter for assigning tag values
tag_counter = 1
for x, y in coordinates:
    # Check if the X coordinate is already in the dictionary
    if x not in tag_values_by_column:
        tag_values_by_column[x] = {}
    # Check if the Y coordinate is already assigned a tag in the column
    if y not in tag_values_by_column[x]:
        tag_value = f'CP{tag_counter:03d}'
        tag_values_by_column[x][y] = tag_value
        tag_counter += 1
    # Find the corresponding pile based on coordinates
    pile = next(pile for pile, coord in zip(selected_elements, coordinates) if coord == (x, y))
    # Assign tag value to the pile
    pile.get_Parameter(BuiltInParameter.ALL_MODEL_MARK).Set(tag_values_by_column[x][y])
# Refresh the view to see the changes
uidoc.RefreshActiveView()
# Output the sorted piles and their coordinates
OUT = [(x, y) for pile, (x, y) in zip(selected_elements, coordinates)]
@Vinay ,
i embedded my transaction in a try statement…
KR
Andreas
Hi Vinay, welcome onboard the Dynamo forum :handshake:
I’m finding your code somewhat convoluted, as I understand what you are wanting to do is
  • Select piles in the current document
  • Get the pile location x & y coordinates in mm (project units)
  • Sort the piles based on x, then y
  • Tag the piles in order with CP000, CP001,...
Some comments on your code
  • Remove code that is not required - there are a lot of imports that can be removed like 'System' and 'RevitNodes'
  • The get_location_coordinates function uses hard coded conversion - use the API UnitUtils to do this dynamically (see my code below)
  • Iterating through the coordinates and building a dictionary, then checking every pile in the zip function is using a lot of cycles as we are doing it every time we test a coordinate - these can be separate operations
  • Your OUT variable does not need the list comprehension as it is only selecting coordinates - just use the zip
Here’s another way to do this operation
import sys
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import BuiltInParameter, SpecTypeId, UnitUtils
def to_proj_units(val):
    units = doc.GetUnits().GetFormatOptions(SpecTypeId.Length).GetUnitTypeId()
    return UnitUtils.ConvertFromInternalUnits(val, units)
def location(obj, tol=0):
    loc = obj.Location.Point
    return round(to_proj_units(loc.X), tol), round(to_proj_units(loc.Y), tol)
def sort(obj, tol=-3):
    # Use rounding tolerance to deal with minor variances (-3 = meter)
    # -Y, X sorting Top left -> Bottom Right
    x, y = location(obj, tol)
    return -y, x
piles = UnwrapElement(IN[0]) if isinstance(IN[0], list) else [UnwrapElement(IN[0])]
sorted_piles = sorted(piles, key=sort)  # Sort list of piles based on location function
for cp, pile in enumerate(sorted_piles, 1):  # Use enumerate to count items
    mark = pile.get_Parameter(BuiltInParameter.ALL_MODEL_MARK)
    if not mark.IsReadOnly:
        mark.Set(f"CP{cp:03d}")
OUT = [(p, location(p)) for p in sorted_piles]
thanks Mike, it has changes coordinate values to sort the piles
this had happened to me as well when i am trying to sort pile as per coordinates this keep changing values and assigning coordinates values to diff piles
i want to sort piles like this, but without changing the coordinate values
for the first row, N value (Y coordinate) is constant and E value (X coordinate) is increasing in that row
and so on
i am inputing my selected piles manually in IN[0] of pyhton scripts
Hello if you remove the - before the y in the return of the sort function,
this should rank in the direction of increasing y
Sincerely
christian.stan
@christian.stan which line, could you please add a snip
hello
    # Y, X sorting From bottom left to top right
    return y, x
cordially
christian.stan
