thank you for your fast response, I really appreciate. I have managed to use it (edit: the first node, Tag.ByElement) with multiple views, I was mistaken in the level to use, I had to set it to level 2 so that it stops at each item of the list (views). So, technically, I have achieved what I wanted, but I am noticing that when I select one of the resulting tags and query Revit to tell me the total number of tags created, I get thousands. So dynamo is placing tags in those views, but also outside of the cropping region, we just don’t see them. They are harmless, I guess, but is there a way to refine the output of the tags node to eliminate tags outside of the cropping regions? Or am I missing something in the node set up? thank you!
