old issue, seems FamilyInstance.TotalTransform doesn’t work on room, any solution (Dynamo or Python)? thanks
edit: cannot install Springs package so cannot use CopyFromLinkInstance either
Why can’t you install springs?
maybe firewall issue, is there another way around like Python?
edit: solved, I should use FamilyInstance.TotalTransform on linked RVT instance instead of linked rooms, thanks all!
