Hi, I have a problem in dynamo. I would like to tag element in a section in revit using dynamo. The problem is becouse the element is in a revit link file.
Thank you
Hi @f.brusiani,
You can use the Create Tag node of the Genius Loci package with linked elements.
I tried using this node and generate the different tags, but the problem is that I can’t see in the sections views the tags.
