I am testing this node, which is said to: “Create a Revit Tag for a Revit Element at an offset location from the element’s view extents.”
So, I used a scaled vector value for the Offset value, and the tags have been simply offset from the center of the element, for that amount.
How do the element’s view extents coming into play here?
I was hoping that the node would accept an offset from the view boundaries where it would not place tags…
Thank you
