Hello all,
I managed to create a script that add tags to all selected assemblies based on Naming Category parameter. I’m arrived at a point where it give me the following warning when i add two GetParameterValueByName node to help the user identified witch assemblies to select.
Also, there is a way to rename the list to something more helpful than using FirstItemTitle option? By using this option the first element that is used to name the list it will not be tagged.
Below you can find the script.
You are not inputting any elements into your datashapes form, you are just inputting strings. Like the error tells you.
Where this happened?
