Hi All,
I’m making an adaptive screen that can adapt (open and close value) according to a gradient / Image I specify. The node works precisely as intended by placing the geometry correctly, but a strange issue occurs that the selected image gets cut and placed diagonally across the surface with the LB. Lunchbox Diamond Grid by Face node. I’ve coloured it in view for visual reference.
The current workaround is to just use the LB. Lunchbox Diamond Grid by Face node to place the adaptive components, then use another script and attractor to control the parameters of the placed component. This is not as successful as using a gradient, and it involves two scripts/parts which I’d love to avoid.
Any suggestions? Or alternatives I can try, or you can recommend?
Please find the script attached, you can use any 4-point or 3-point adaptive component and any gradient / image.
Thank you,
KM
Scale_Adaptive.dyn (1.5 MB)
