I am working through the Computational Logic I video tutorial, using Dynamo 0.7.4.3245 (current stable build). This version does not appear to include a SunPath Direction node. Searching the Library for sun path returns no results. Navigating to Revit > Selection, there is no SunPath Direction node. If I open the Computational LogicI.dyn tutorial dataset file, there is a node called SunPath Direction, but it is labeled as Unresolved. Was t
his node dropped from this version?
The SunPath Direction node is still missing in the recently released Dynamo 0.7.5.3566 stable build.
David,
Maybe you can use these nodes -
Thanks! That worked.
Hi Assem, I am following the exercise too and suffering the same issue.
could you please paste a clear image if convenient?
Thanks in advance.
Frank
The old SunPath Direction node can be replaced with the SunSettings.Current and SunSettings.SunDirection nodes.
cool. it works, Thanks David.
