gatum
December 9, 2017, 2:34pm
1
Hello everyone,
I’m trying to place views on sheet using steam node but its not working and giving null
The work flow takes room boundary, crop plan, place the cropped plan view and key plan from (area plan)
on sheet.
Any suggestionsExport room pictures v1.dyn (32.3 KB)
gatum
December 10, 2017, 7:16am
2
I already checked previous similar issues but the solution didn’t fix the problem, it keep giving null
Kulkul
December 10, 2017, 8:06am
3
Hi @gatum
Try this workaround if you still face issues upload your rvt file.
gatum
December 10, 2017, 9:17am
4
Thanks sir, it did workout that way I really appreciate the help.
I think I will try to edit the node python code, to not use the chop list node
Hey Gaber, were you able to modify/update the script to avoid using the chop list node? also do you guys know the logic behind why the list needs to be chopped?
