Stair Rebar Code Error
Hi, i was making a code to select the lower part of my stair to make more automatic, but look like im not getting it done, can someone help me?
the code:
the stair:
It’s a bit difficult for me to understand the issue without files and just from what you’ve written. Based on what I understood, I made a simple version of what you’re asking for. You can improve it from there. I did it using the Structural Design package in Revit 2025 and Dynamo 3.2.
Home.dyn (33.2 KB)
If you want your rebars to be grouped, you can create one curve and use the SetLayoutAsMaximumSpacing command.
