Running Error
In the part of the image that I selected within the black block, when I convert my curves to rebar, Dynamo gets stuck during running and then the program becomes unresponsive. Previous codes, including the green group labeled “Working,” are functioning.
The purpose of my code is to automatically shorten the reinforcement if a beam does not follow a column.
BeamReinforcement.dyn (372.1 KB)
Project1.rvt (8.0 MB)
I am testing on the beam that I circled in the Revit file.
If there is an alternative solution to what I am trying to achieve, I can apply that instead of dealing with the existing error.
try this package and see if it works.
I made some changes to the code, I’ll try it. Thanks!
