Hello! I am trying to add structural parameters to the stairs, so i can join them with the walls. Does anyone have an idea how to do it?
we use sharedparameters (projectparameters) map the structural topics also the Pset (ifc) stuff…
KR
Andreas
Thank You for such a fast reply. It took me a while to process your answer. Which parameter type am I supposed to choose? Because non of them is the YES/No option for structural element. There are only parameters related to forces and its distributions plus the reinforcement.
do have some pics to visualizese your issue ? how would you do it analog…
KR
Andreas
from the shared parameters i chose weight in structural discipline, then attached it to my stairs in parameter properties. It actually did work and made stairs as a structural object, but the very problem of mine, that i can not join walls with stairs was not fixed. Do You have any ideas why is that?
