Springs.Element.SetLocation Not Working
Hello all,
I am trying to use Springs.Element.SetLocation to move a Reference Point in a conceptual mass. You can see my graph in the attached picture. I think I have everything set up correctly but the RP does not move.
Also I know that in 1.2 there is a new built in node for moving Revit objects but I am stuck with 1.1 for now :frowning:
Hi @Steven_Hansen
Element.SetLocation nodes expect points as location currently your feeding vectors.
Kulkul,
I tried setting the Set Location with a point instead of a vector but it still does not work. I can see the dynamo point moving but the Revit point is still in same spot.
What type of element are you trying to move?
A Reference Point in a Conceptual Mass.
I’m having similar issues. Afraid i don’t work much in the massing environment so I won’t be of much help here. Maybe try re-building the mass by importing points, filtering the one you want to move out of the list, adding the new point, and recreating the geometry?
The problem is I am trying to control the geometry indefinitely. Right now if I close out of Revit Dynamo losses all association with the model. Then when I try and update it I need to start all over again.
This might be happening because the point is hosted on a line or a plane and you’re trying to move it off its associated plane. In that case Revit will just ignore the command.
Dimitar Thanks for the reply,
Reference points can move off of the plane though. They are hosted but should be able to move anywhere. In any cased though it wont move in any direction even across the planes surface. Any thoughts?
Thanks,
Steven
Had a thought last night about this and ran a little experiment on my lunch break. I thought that it might have been due to Revit preventing people from editing an in-place mass without opening the “edit in-place” command. Dynamo won’t run much of anything for me when I start that command. Sadly it’s also non-responsive when I was in an conceptual mass family.
So i tried wiring in an element.location node to the reference point and found some odd results - namely i’m getting a FALSE result for “Has Location
This occurs even though the location is clearly listed in the watch node for the element and it clearly has a point as we can create geometry for and by it… I would water that these problems are linked. Sadly my python and API knowledge aren’t advanced enough for me to confirm in the time I had available, and likely are nowhere near far enough along to fix the issue at hand.
Thanks for the effort @jacob.small. You have made more progress than I have. I will keep looking though and report back when / if I find something.
Had a quick look and yes, reference points do not have a location property. Instead they are controlled by a coordinateSystem/Position property that can be set through the api…gotta love Revit :slight_smile:
http://www.revitapidocs.com/2017/4f540b05-f562-8a72-37ef-834d45cea027.htm
@Dimitar_Venkov you’re the man!
hi guys can you share the python script if you already made for this ( I want to move a reference point in massing environment)
or let me know if there is any node for like set element location by coordinate system
Hallo Dimitar , could you please share the solution for the Element location , i would be very appropriated.
Yes Could You Please share script with us
This (very basic, you’ll want lots of error catching) code works for me…
test
#credit & thanks to everyone
# Import RevitAPI
clr.AddReference("RevitAPI")
pointsList = UnwrapElement(IN[0])
zValuesList = IN[1]
locations = []
for point, newZLocation in zip(pointsList, zValuesList):
	locationX = point.Position.X
	locationY = point.Position.Y
	newLocation = XYZ(locationX, locationY, newZLocation)
	point.Position = newLocation
OUT = pointsList
Cheers,
Mark
but İs ıt jus for z value ?And I also wolud like to change values for every single one bye one
Hey,
I tried to give an example code which shows you how to do things… you can customise it as you like, e.g. if you want to input X values as well, you can just make a new input
xValuesList = IN[2]
then you can amend your zip…
for point, newZLocation in zip(pointsList, zValuesList, xValuesList)
and use your X values…
newLocation = XYZ(newXLocation, locationY, newZLocation)
Cheers,
Mark
Edit: I think that you can feed a list of points and use .ToXYZ() to convert them to a Revit element
Like this?
# thanks ALL esp Konrad & Dimitar!
# Import Element wrapper extension methods
# Import geometry conversion extension methods
# Import RevitAPI
newLocations = UnwrapElement(IN[1])
for point, newLocation in zip(pointsList, newLocations):
	point.Position = newLocation.ToXyz()
OUT = pointsList
