I’ve been working with this awsome node to extract the sketch curves of floors, however, for walls the node can only do “modified walls”. This means that if the walls has a regular (rectangular) shape, the node will not give me the sketch curves. Does anyone know a workaround for this? or, do you know how to change chage the wall type to “modified” without changing the geometry?
My bad! That’s because I was using a custom package and you don’t have it installed.
Please try this alternate approach which uses only the OOTB nodes.
AmolShah,
Thank you! This is working now. It is not quite the same as the Collect.ElementSketch node but I think I can make it work.
