I madeTag - Spot Elevation.dyn (13.9 KB)
Hi all,
here is the script for placing spot elevation by point (Clockwork) and it works fine with cable trays and ducts, but i just cant get it to work with pipes! Also, as you can see in the picture, when i run dynamo, it leaves the line and point behind the duct, i cant select that line and it disappears when i turn off Generic Models in Visibility Graphics.
Thanks in advance for any help you could provide.
