I am having issues using the Clockworks node SpotElevation.ByPoint. It is causing a generating graphics for 3D view loading bar and takes several minutes to complete for just a handful of elements.
It also does not seem to work at all with linked model elements even though it is only being fed with a point and not the linked element.
My end goal is to place spot elevations at points where pipes from one linked model intersect walls from another linked model.
I am using Dynamo 2.6.1.8850 in Revit 2021. Any help would be appreciated thanks!
I created a simple graph below just to test the node.
