Hi.
I have a small script going to thats takes inn a closed loop of model lines and a topo surface as input. It extrudes a solid that passes the toposurface and then traces the shape of the toposurface to the solid. The solid should then be split into two parts. One below and one over the topo.
The solid is made and the trace of the topo is visible on the solid, however, the solid don’t split into the two parts. Do any of you know of a workaround of Geometry.Split?
I have made screenshots of the script, the input and the current output.
(PS! This script used to work in 2017, but I cant make it work on toposurfaces made in Revit 2018.2)
Edit 1: Added.dyn
3-3-4_CutObject.dyn (20.3 KB)
Revit file can, due to size limits, be downloaded here: https://ufile.io/h7zbl
