Split imported solids in subsolids
Hello all!
I need some help and I hope the question is not too difficult…
I have a 3D AutoCAD file and need to identify all the sub-solids composing it.
Once this is imported in Revit, I need to recognize the solid inside it as separated geometries and after that, I will transform them to single families.
Well… I have no idea how splitting the geometry in separate sub-geometries… any hints??
Just imagine that my final scope is converting all the boxes and the cylinder in the image as separate families in Revit.
Many thanks in advance!
I think you need the node: Geometry.Explode
that node explodes all the geometries in single surfaces; I need to have all the solids instead
But can’t you recreate the solids after you explode it with the separate surfaces with Solid.ByJoinedSurfaces
You can, but from my experience, that tends to recreate a single solid. There are some workarounds for this issue, but there’s gotta be a way to get seperate solids more simply; a way that doesn’t involve recreating them from extruded surfaces and polylines. That approach is not always favorable with more complex geometry.
Has anyone had more luck with this?
@dcmasten1, so, did you find a way to solve this ?
I do have the same problem, made so research but quite a mess to find a proper solution !
I found a method that takes very few nodes, but unfortunately may not work very quickly, depending on your circumstances.
The problem is that it may take a while to ‘put Humpty back together again’!
We are creating a new node to do just this in Dynamo 2.9 :slight_smile:
It will be called Solids.Separate. Feed in a composite solid (i.e. a solid that is in fact multiple solids) and it will split them out without having to explode stuff.
PR here: https://github.com/DynamoDS/Dynamo/pull/11135
That is exactly what we need. I am guessing that the process which Dynamo uses to separate a composite solid would be different from the one shown above. It would be awesome if this was an instant computation.
That’s actually a very good news ! Any clue to do this in older version ?
I will try the @daniel1 solution, but my geometry is so damn complex, I think a night will no be sufficient to calculate all the process !
Somebody knows a package ?
