Hi guys!
Is it possible to create a routine that creates an individual file for each layer of my dwg containing only its objects?
I know it does not sound like a good practice, but sometimes we must deal with the problems as they appear…
Also, I’ve found a LISP that seems to do that but I’m not sure about its safety, have any of you used it?
(https://www.cadforum.cz/en/qaID.asp?tip=3682)
Hi @apegaia,
If you’re able to upgrade to Civil 3D 2025.1, there is a new node called Object.Export that seems like a good fit for this. You could group your objects by layer using the List.GroupByKey node, then decide on the file naming scheme that you want to use.
For older verisons of Dynamo, you can use this code:
import sys
import os
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
aDoc = Application.DocumentManager.MdiActiveDocument
cDoc = CivilApplication.ActiveDocument
ed = aDoc.Editor
def WBlockMultiple(paths, objectSets):
if len(paths) != len(objectSets):
return "The number of file paths must match the number of object sets."
global aDoc
global ed
for i in range(len(paths)):
path = paths[i]
oHand = objectSets[i]
oic = ObjectIdCollection()
with aDoc.Database as db:
tr = db.TransactionManager.StartTransaction()
with tr:
try:
for handle in oHand:
newhandleint = int(handle, 16)
hexa = Handle(newhandleint)
oid = db.GetObjectId(False, hexa, oHand.index(handle))
oic.Add(oid)
with Database(True, False) as newdb:
db.Wblock(newdb, oic, Point3d.Origin, DuplicateRecordCloning.Ignore)
newdb.SaveAs(path, DwgVersion.Newest)
ed.WriteMessage(f"\nSuccessfully saved to {path}")
except Exception as e:
ed.WriteMessage(f"\nThe process failed for {path}: {str(e)}")
return "The process failed for one or more paths."
return 'Completed'
paths = IN[0]
objectSets = IN[1]
Log = WBlockMultiple(paths, objectSets)
OUT = Log
Thanks! Good to know we’ll have a native way of doing so! I think I’ll use it on future projects!
Man, you’re literally a legend!!
I was thinking with myself if there was any way to use the wblock function to do this, and I think adapting this script will be really perfect to do so!!
Really can’t thank you enough for this! Hahah
