Civil 3D dynamo BIM export solid as new .dwg file
Good morning all,
I have some 3D solids exported from corridor and defined with it’s own on filename and file path define in a list of file paths and solids in for each separate exported file.
Could someone share any workaround or scripts to achieve this?
@Paolo_Emilio_Serra1 I saw you did similar script to Export objects to new dwg, I would highly appreciate it if you could help.
Kindest regards,
Giada,
Hi Giada
How did your work went? Did you found a solution to export to new dwg?
Regards,
Patrick
