This is my first time using Dynamo and my first experiance of python scipting so forgive the ignorance/silly questions;
I have a spreadsheet that has a load of layer names that I want to import into CAD, which may also help to formulate a CAD standard check using dynamo (if I can get my head around it) but I can’t for the life of me work out how to get the layer names into CAD.
I have looked through the forum and although the answer may be there; it is unfortuantly not in a forma I cam familar with or currently understand. I found a custom node on here that someone has dont that create new layers from a string value in either the string node of code block node; however as I am importing from excel it isn’t just one string value but a list of string values.
I have managed to get the following:
but i can’t work out how to get the list into the end node. I have a feeling it is because the node is written to only accept a singular value/string not a list; unfortunately I don’t know how to change the python script to read the list as a series of strings - can you help me?
