Is possible to execute that Revit button with python node?
This is only exposed via postable command, which makes sense as there is a required degree of UI. That it is a postable command means it’s difficult to make work via Python.
same answer if I want to reset coordinates to origin 0,0,0?
Unfortunately that command is also listed in the link above.
I am sure there are workarounds to get the same result, rather than a direct API access.
Nope - you’ll have to manage to get the postable command to work. This is something I haven’t managed before.
Just wanted to know if someone got it worked out or not.
