I’ve noticed that the Spec Types & Group Types nodes do not retain their values.
Specifically they seem to go blank if the graph has any opening of models in the background happening. Not sure if this is something that can be fixed.
I’ve found how to avoid using the dropdown nodes. Thanks @awilliams
Revit 2024.2 Dynamo 2.19.3
They are the OOTB ones.
I’ve found out that they only get cleared if I have the graph open in dynamo when running it.
If I run the graph through Orkestra the nodes stay set to Text.
Yes, I can. I’ll try to get it to you sometime this week. I have a feeling it has to do with the amount of other things I have going on in the graph. Just got out of a meeting and now I need to make a couple more updates to the graph first.
