Dynamo 2.13 Get all Parameter Group Types
Hello there!
I’m building a dynamo graph to create shared parameters from an excel file in Revit 23, using Dynamo 2.13.
The Spec Types issue is solved with @c.poupin answer in @Sean_Fruin’s topic:
However, i’m can’t find a way to get all Group Types (Revit.Elements.GroupType or Revit.Elements.GroupTypeId)
So i really need some help.
Thanks.
I think i’m getting closer, but not good enough…
#import Revit API
clr.AddReference('RevitAPI')
gN = []
gT = []
prop_infos = clr.GetClrType(GroupTypeId).GetProperties()
for p in prop_infos:
    gN.append(p.Name)
    gT.append(p)
OUT = gN, gT
try this
import sys
#import Revit API
dict_forgeGroupTypeId = {p.Name : p.GetGetMethod().Invoke(None, None) for p in prop_infos}
OUT = dict_forgeGroupTypeId
Thanks a lot @c.poupin!
That was the key to unlock the solution.
Python script after Dictionary.ValueAtKey:
import sys
forgeTypeIds = IN[0]
output = []
for id in forgeTypeIds:
    output.append(id.TypeId)
OUT = output
@c.poupin i notice that the values of project parameters created by the dynamo graph don’t show up in element tags.
However, that issue doesn’t exist if i create the project parameters manually.
Do you know something, that can prevent this issue?
Hi, @simoes.rja
create a new topic, your question is not related to this one (and the topic has solved)
