Space Tag Text
One of Marcello’s scripts for changing text to UPPER case is simple and works just fine. I tried to utilize this for Space tags, but cannot find a “Set Text” node for tags to match the TextNote.SetText node. I tried "Set Parameter, but that won’t work either. See attached images below. Everything works fine (as seen in the drop down) until I get to the PUSH node. Thanks
You can’t set parameter values by editing the tag. You need to go to the element which they take the value from instead.
Makes sense
Re-wrote my script, now it works
