Sort Type Elements by Name and Change its parameters Values
set your lacing back to auto, what does the warning say, are your sure the parameter value is a string try to remove “” in the codeblock with 20
I already set lacing back to auto, I This is the warning " Warning: Element.SetParameterByName operation failed. The parameter’s storage type is not a string "
yes…just feed in 20…hope thats help
wow, It helped , thank you so much. But the parameter value in properties is not filled in .
strange…try to open and close dynamo…does “set parameter” gives you the element in preview
