Some way to add sample sources with Dynamo in Civil 3D?
Sorry, I missed the part that you wanted to add surfaces.
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
from Autodesk.AutoCAD.EditorInput import *
# Import references from Civil3D
dataEnteringNode = IN
editor = adoc.Editor
sampleline = IN[0]
def addsource(sampleline):
	with adoc.LockDocument():
	    with adoc.Database as db:
	        	#Get sample line ID
				slId = sampleline.InternalObjectId
				#Get sample line group ID
				slgroupId = slId.GroupId
				#Open SLGroup
				slg = t.GetObject(slgroupId, OpenMode.ForWrite)
				#Get sources
				slgs = slg.GetSectionSources()
				#Get source item
				source = slgs.Item[0]
				#Add the source item above
				#source.IsSampled = True
				#Add all sources
				for source in slgs:
					st = source.SourceType
					if str(st) == "TinSurface":
						pass
				# Commit before end transaction
				t.Commit()
	return st
OUT = addsource(sampleline)
Add SLsource.dyn (5.6 KB)
