Hi! I recently started to learn and use Dynamo in my workflows and I’m impressed with it. One of my current task is to add a couple of surfaces as sample sources to some Section Groups and I thought Dynamo could help me.
I found the popular and helpful Civil3DToolkit but also I couldn’t find some node to do the job. I searched in Sections, Corridors, Basselines, SectionViews but… nothing. So, as this topic says, is there someway to add sample sources using Dynamo? Maybe I’m looking for nothing mplemented yet (⌒_⌒;)
Note: I’m asking mainly for nodes but I know basic Python so a custom code solution would be welcome too.
Welcome to the Forum. You can do it using the .net API and the python script node.
You can use this code as a starting point:
import sys
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
dataEnteringNode = IN
editor = adoc.Editor
sampleline = IN[0]
def addsource(sampleline):
with adoc.LockDocument():
with adoc.Database as db:
#Get sample line ID
slId = sampleline.InternalObjectId
#Get sample line group ID
slgroupId = slId.GroupId
#Open SLGroup
slg = t.GetObject(slgroupId, OpenMode.ForWrite)
#Get sources
slgs = slg.GetSectionSources()
#Get source item
#source = slgs.Item[2]
#Add the source item above
#source.IsSampled = True
#Add all sources
for source in slgs:
# Commit before end transaction
t.Commit()
return slgs
OUT = addsource(sampleline)
Sorry, I missed the part that you wanted to add surfaces.
import sys
sampleline = IN[0]
#Get sample line ID
#Open SLGroup
#Get sources
#Get source item
source = slgs.Item[0]
#Add all sources
for source in slgs:
st = source.SourceType
if str(st) == "TinSurface":
pass
t.Commit()
return st
Hi. I’m trying to add sources (surfaces and corridor) to sample lines. It seems that your Python code can do that but I don’t have so much Python knowledge to understand it. Can you give reference to how to use that? Or do you know a better way to add sources? I hope you can help me. Thanks you so much.
Hi @kovacsv,
I have problems to use your example Python code. I have Civil 3D 2023. There is error and Civil 3D shuts down. Have you tested this on 2023 version with Python3?
I made this almost 2 years ago, I’m sure it was made in IronPyton 2.7. Try running it with 2.7 maybe it drops an error message. We used another version of this with corridors a few months ago, we did not experience crashes.
Hi @Drbohlav and @raul.07.11 , I have modified the code by @kovacsv to work with the CPython3 engine and to add surfaces and corridors. I am a complete beginner with Python, but I tested it with Civil 3D 2025 and it works.
import sys
# IN[0] is a single Autodesk.AutoCAD.DynamoNodes.Object
sampleline = IN[0]
# Lock the document explicitly
doc_lock = adoc.LockDocument()
try:
# Get the database and transaction manager
db = adoc.Database
tm = db.TransactionManager
# Start a transaction explicitly
t = tm.StartTransaction()
try:
# Get sample line ID
# Open the sample line object
slObject = t.GetObject(slId, OpenMode.ForRead)
# Get sample line group ID
slGroupId = slObject.GroupId
# Open SLGroup
slGroupObject = t.GetObject(slGroupId, OpenMode.ForWrite)
# For debug / info, get sample line group name
slGroup = slGroupObject.Name
# Get sources
slSource = slGroupObject.GetSectionSources()
# Initialize sourceType in case there are no sources
sourceType = None
sourceName = None
# For debug / info, store all sourceType values
sourceTypes = []
# For debug / info, store all sourceName values
sourceNames = []
# Add all sources
for source in slSource:
# sourceType is an int
sourceType = source.SourceType
# sourceName is a string
sourceName = source.SourceName
sourceNames.append(sourceName)
# From observation, 0 is TinSurface and 2 is Corridor
if sourceType == 0:
sourceTypes.append("TinSurface")
if sourceType == 2:
sourceTypes.append("Corridor")
pass
t.Commit()
finally:
# Ensure the transaction is disposed properly
# (guard against older API versions that may not have Dispose)
if hasattr(t, "Dispose"):
t.Dispose()
finally:
# Release the document lock
if hasattr(doc_lock, "Dispose"):
doc_lock.Dispose()
# Return a list of added source names and types
return [slGroup, sourceNames, sourceTypes]
# Assign output to the OUT variable.
Caution
However, I found Civil 3D shuts down if I use it in a flow with SectionView.BySampleLine, but I will open a new topic for that issue.
