Some problems met in the use of BimorphNodes
Warning: One or more input types do not match. The version of LayerNames with the type (Revit.Elements.Element) parameter could not be found :sob:
how can i solved it?
What is your input?
the dwg file linked in revit
i just want to catch the axis of the dwg file
Can you share your dwg file?
i have just solved it.
The problem why it happened was the version of revit and the node package were not compatible.
Thank you~~ :grin: :grin:
:slight_smile:
